dattodude »
https://forums.nicoclub.com/dattodude-u30125.html
Mon Mar 27, 2006 1:12 pm
Two of you fellas have mentioned o-rings. How can this contribute to petrol in the cylinder? A busted o-ring might lead to petrol on the outside of the injectors or around the intake side of the engine, but not in the cylinder.
The Ohmmeter test is interesting. I know the manual says to check the resitance. But it is a go/nogo kind of test. This fellas engine runs ok, so all will pass that test.
He needs to take the car to a mechanic, or needs to get creative with some spanners and pull back the fuel rail and remove the injectors.
Put them in a ziplock plastic bag and take them to an injector specialist or workshop that can clean the injectors. Some injector places can't do SR20 injectors, but all will do CA18 topfeed ones.
Some leaky injectors can't be fixed, and will need replacing. Sometimes a good ultrasonic clean will fix them up. Most injector places will then flow test and spray test them.
Cheers,Chris
