Look behind your driver seat, pop the middle section carpet up, youll see a plate with a few bolts on it. Under it is your fuel pump. Check the float, and more importantly, there is a potentiometer that could be either worn out or broken. The little metal looking thing is supposed to touch the thingey with the numbers. If the thnigey with the numbers is worn down, or they dont touch, you can contact me at
[email protected], I can sell you a fuel pump assembly for cheap. If the\ above checks out, you have a short/cut sumwhere in teh wiring, or you have a cluster issue. Do fuel pump first, then swap clusters.
