240sxmech »
https://forums.nicoclub.com/240sxmech-u57620.html
Tue May 29, 2007 3:05 pm
gas is not gray, but if you mix coolant with oil you will get a chocolate milky color might be what your talking about, cause of that is a blown head gasket or a cracked block or a cracked head or a hole in your timing chain cover around the water jackets. What color is the smoke?blue is oil burning,white is coolant mixing in the combustion chamber,black is running to rich. Be more specific when you post on here. Like saying when i turn on the car gas mixes with oil and smokes alot, do you mean when its running and tell us what color the smoke is. You will get more replies when you take the time to inform us of your problem .
