nmaiorin »
https://forums.nicoclub.com/nmaiorin-u162676.html
Tue Aug 17, 2010 11:26 am
4 cylinder engine are extremely hard on ATF fluid because of their nature, very high stall speeds on the converters and very high RPMS - stressing fluid in almost any climate zone.
Every one on this board with the Auto 4 speed should change their fluid between 30-60,000kms depending on driving style and inspection.
I usually change my cars at 40-50,000kms - My versa's fluid was black and nasty at 50,000kms and after 4 drain and refills the trans hooks up better and is getting better mileage.
FYI - I have other threads on this board discussing the virtues of fluid changes.
You change your engine and often forget about the most complicated component in your car - the transmission.
Manual transmission are usually much easier on fluid compared to conventional automatics.
Cheers
