solid wrote:I have a 95 240 se with 170k on it. I get 250-280 miles per tank, is that normal? i heard from other 240 owners thats below the mileage that i should be getting. What do you guys think i should do, tune up? new engine? What? Thanks
I'll try to help you out here. What kind of driving do you do? If those are mostly highway miles, then you definitely need some work.
If they're all city, then you're not too far off. I would make sure the car has a good tune-up anyway. Make sure your O2 sensors are good. When they're fouled, they really waste a ton of gas and power suffers as well.
Driving style also has a lot to do with it. Are you on the throttle all the time?
