They are NOT known to destroy MAFs. Dunno where u got that info from. The only part that is bad for the MAF is if you lube the filter up too much with that oil the filter uses, but you only need to do that like 1-2 times a year if that. Plus your supposed to clean out your MAF element at least once a year anyway.MattB wrote:Lose the K&N air filter ASAP. They are known to destroy MAFs.
