Last Christmas I drove from Ft Lauderdale to Tampa, 265 miles. I filled up the next day & calulated my mileage based on my trip odometer & gallons to fill back up full, going @ 70-75 mph the whole trip & it was @27 mpg. In 2003 I drove from Marathon FL to Tampa one a full tank, F to E with low fuel light on at the end, @380 mile but that was going on average 90 - 100 mph.joetraynor wrote:- My J30 T does not get the best milage per gallon. What is the average milage per gallon for the J30 T. Is there any small fixes i can make to improve my MPG?
27 mpg is a stretch. Florida must be totally non-stop and flat in all directions. Did you use cruise control? What's the engine rpm at 70-75 mph? Maybe the later models get better gas mileage? 380 miles on a tank full is 20-21 mpg.J30inthe sun wrote:
BTW @27 mpg is with 4 new Goodyear Eagle ResponsEdge tires (215/60/15) with about 1,500 miles on them set at 29 psi cold.
I guess I should have said @26 mpg, thinking back about it I remember it was 26 point something. I wonder if there was any drafting effect because I remember following alot of traffic.GerryO wrote:
Yeah!GerryO wrote: Florida must be totally non-stop and flat in all directions. .
I find your post highly offensive.HymroD wrote:
full of ...PEDERASTS ...HymroD
Correct me if I am wrong but doesn't the weight per gallon (a measure of volume) of gas change with ambient tempurature? Denser at lower temps results in 1 gallon weighing more at 40F than 90F.Q45tech wrote:...if gasoline weighs 6.2 pounds [2815 grams] per gallon...
OKyodawill2000 wrote:...The weight won't change a bit...
OKyodawill2000 wrote:...Put another way, a gallon of warm gasoline will weigh less than a gallon of cold gas...
My point precisely which is why the equation should be in volume not weight.yodawill2000 wrote:...the denisty of the gas changes. It becomes less dense as it heats up... a gallon of warm gasoline will weigh less than a gallon of cold gas. The volumes are the same, but since the densities are different, they don't have the same weight...
