gas milage
hatefulkeel
Car: 1995 240 sx
ive got a 95 240 and im only getting bout 17mpg! replaced o2 sensor and still no change. what could it be?
gumby74
Tune up time.Break out the timing light as well and buy you some mas air flow sensor cleaner. Check all your sensor plugs for corrosion.I was having the same issues, it turned out to be a failing maf sensor connector. Had some green corrosion. A good cleaning of all my connectors and a tune up had me getting 25mpg.
Shift_Kouki
Car: 95 Nissan 240SX SE
When I first got my car I got pretty crappy low 20's mileage w/ the automatic trans. As soon as it was a 5spd, I could get 28.89mpg highway.
I got real real bad MPG right after I installed my header. ~19-22 (cruise control for the whole tank at 70mph on the highway) -- Mileage was just as bad w/ the stock exhaust as it was open header.
It continued to be bad like that until I had a 2.5'' exhaust fabbed up for the car. Suddenly I jumped to ~27-28mpg highway.
I don't know if this will help you... but that was what I observed. The cause seems apparent, but I have no way of knowing if that was the cause of the improvement or not.
If you have not had anything done to the car, check it over and tune up things that need attention. Air filter, check compression, check condition of plugs and wires, maybe condition of injectors, and then everything you can think of that is electrical, lastly all your emissions stuff.
hatefulkeel
Car: 1995 240 sx
thanks guy, ill try that
480sx
Car: 1996 Pearl White 240sx
A fualty knock sensor can also cause terrible gas mileage. Same holds true for the CLT sensor. Replace atleast the CLT sensor first and see if that fix's it, they are cheap.
First thing to do however is a basic tune up, plugs, wires, cap and rotor.
Ryans13se
Car: 1989 nissan 240sx
Check for leaks and clogs. tune up and flush your engine
r3v_v3ng3
Car: 91 fastback ka-t
don't forget about tire pressure and wheel alignment
r3v_v3ng3
and oh yeah, heavy foot
hatefulkeel
Car: 1995 240 sx
guilt as charged
