loystock »
https://forums.nicoclub.com/loystock-u10145.html
Thu Jul 22, 2010 7:46 pm
You have to provide the trouble code. Depending on the extent of corrosion, it may require special treatment chemicals or even replacing the fuel tank. Keeping the fuel tank close to empty most of the time, especially if one lives in a humid area, will allow rust to set in causing lots of problem - hard starting, plugged injectors, backfiring, etc.
