GAS LEAKING!!! HELP ASAP!!!
deevietboi
Car: Nissan 240sx 1990
ok so i turned my car on today after a while of no driving... all this gas started to leak crazy at the fuel tank
its a 1990 hatch s13i opend the hatch to see if there was a leak inside but noneit was all coming out from the rear right side.
what could be the problem?i need to no asap cause that ****s scary!
neverlift
clearly dont drive the car. let the car air out for a bit then disconnect teh battery!!!
the lines going to or from or purge,are old and fuct. tank needs to be dropped and new lines ran. IF your a peformance guy you could go ahead and upgrade your lines... good luck.
deevietboi
dam so its out of comission for a little bit....
deevietboi
so where can i get those hoses and lines?how much do they cost?
and can i do the replacement myself or wil i need to take it to a shop?
