gas leak
SRpiccalo
Car: my car
i'm leaking gas from the bottom of my gas tank? no visible cracks or leaks i can't see it any ideas?
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Then how do you know its leaking from the gas tank if its not visible? Try checking fuel lines etc.
Cyberkreig
Car: 1993 Nissan 240SX SR
I had a rust hole higher up on my S13s tank. Couldnt be seen without dropping the tank. Cheap to fix, fill with water, weld.
SrSLeePeR
maybe its your gas tank O-Ring...
SRpiccalo
Car: my car
i did check that and replaced that today but i'm still leaking i'm pretty sure it's my fuel lines because the car doesn't leak when it's turned off so it's gotta be the lines so i'm gonna drop the tank and replace em all, has anybody ever had this problem?
SrSLeePeR
You don't HAVE to DROP the tank. They're just rubber lines...99cents/ft at Autozone..I replaced mines as well last week...Bought 10 ft of it just to make sure I have more than enough. I feel much more relief replacing a 13 yr old fuel line..
SRpiccalo
Car: my car
doesn't it kill your hands if you don't drop the tank?
