gas leak? smell of gas is gettin me high
z32Odoom
Car: 1993 300zx N/A 2+2
So I just had tons of work done on my car. Some maintenence. Mostly to get it to pass smog. Which it finally did thank god. Now everytime I. Turn my the heat on the car smells like unburned gas reeaaally bad. The only thing I've checked is by the fuel filter. It doesn't make sense to me. Doesn't it pull air from the cowl? Has anyone had problems similar to this? Or any information at all.
Please and thank you
EM.TT
Car: 91 300ZX TT
08 Silverado All-Star
07 R6 (track)
I had this same exact problem, but it was after I put injectors in. It turned out that I forgot to either tighten a fuel line clamp down or had a bad injector o-ring. I would just check near the fuel rail when the car is running and check for any leaks.
z32Odoom
Sweet. Thanks
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
z32Odoom
Sweet a**. I'm probably going to do that today
BigTDogg (MA)
z32Odoom wrote:Sweet a**. I AM going to do that today
Fixed :)
That is, unless you wanna be z32oBOOM :eek:
z32Odoom
Haha. Well the car is cursed. It wouldn't suprise me if it exploded. It would be on par with its normal shenanigans
es.biggs
Car: 1990 300ZX 5sp NA
LOL you guys are funny.
Had the same problem until I replaced all my fuel lines with new hose :)
z32Odoom
It looks like its my fuel damper. I'm going to take a better look at it tomorrow. See if its just a loose hose or something
z32Odoom
In case anyone was worried for my well being. I got under the hood today and tightened all the loose fuel lines (3). Then rode around with the heat on. It appears to be fixed. So yay! A no money fix!
es.biggs
good job!
