Gas leak problem
ADF932
Car: S13
When ive been driving around These past few days theres been a strong smell of gas in my car. I cant really pinpoint where the leak is at. Has any one ever had this problem?
onosqv
Car: '92 240sx Vert
If it's inside your car, have you tried checking the fuel tank lid (not the gas filler area, but the one beneath the trunk carpet) area in the trunk?
pop the hood & see if the smell is coming from your engine bay and seeping thru your car from holes/crevices?
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
I had this problem when I bought my car and couldn't figure out what was wrong. When I put a Z32 filter on I found the issue. The previous owner had used an aftermarket(cheapo) filter, and it required larger diameter fuel lines than the stock hard fuel lines!! I was letting gas seep out around the hard lines. I changed the lines to the correct size when I put the new filter on. I'm glad my motor never caught fire. Might not be it but is worth checking your lines to see.
Felipe
Car: abcdefghijklm nopqrstuvwxyz `1234567890-= ~!@#$%^&*()_+
brokeAs240sx wrote:If it's inside your car, have you tried checking the fuel tank lid (not the gas filler area, but the one beneath the trunk carpet) area in the trunk?
ADF932
Car: S13
Ok I found a cracked fuel line near the main fuel pipe were you put gas. I should get that replaced tommarrow. And it seems that the smell is coming from the Fuel lid under the trunk carpet, what do i need to do about the Fuel lid part?
boriquaS13
Car: 92 240sx
Time to get dirty and remove the fuel pump access panel and check for leaks at the seal that goes around the fuel pump housing and check the fuel lines that you can see there good luck
ADF932
Car: S13
Thanks Guyz . This problem was really bothering me.
