EZcheese15 »
https://forums.nicoclub.com/ezcheese15-u102.html
Mon Jan 06, 2003 6:25 am
Hmmm.....I wonder if your gas cap has somehow sealed up it's pressure release valve thingy (whatever you call it). Basically, presurrizing the tank too much, which may be causing the system to purge, and while it's purging, it purges raw fuel rather than just the fumes, because the pressure is so high?
It's a wild guess, but you may want to think about it. I don' t know. Maybe try a different gas cap.
What year is your car? Is it OBDII? If so, you should have a check engine light.
