evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Aug 28, 2007 7:18 am
Welcome to Nicoit's normal to get a slight amount of gas into your oil,this is caused by blowby, basically the pisotn rings have a small gap in them to allow for expenasion, and you are going to get a very small insignificant of blowbuy on all engines, however if you're getting that much it could mean bad rings, which means rebuild, a compression test will tell you the condition of the rings, also if your fuel injectors are gunked up adn t atomizing the fuel well it can cause the fuel to come streaming out which is more prone to leaking, try using some high quality fuel injector cleaners,. a better spray pattern will have better atomizationa dn less of the fuel can leakdown
