Logan76 »
https://forums.nicoclub.com/logan76-u38992.html
Wed Oct 18, 2006 1:41 pm
Say if it were because of a bad piston ring. It would most likely erode away at your other piston rings, because gas is corrosive, and oil is a lubricant, if you think the ECU caused you to run hardcore rich. and you have that problem settled, an oil change may be a good idea.
Modified by Logan76 at 5:39 PM 10/18/2006
