OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Tue Feb 23, 2010 12:50 pm
Flooding the tops lets gas leak down into the crank case. Compression probably isn't that great, but rings arent always liquid proof when the cylinders are filled with gas.
Drain oil, fill with cheap oil like Kendall or something, run a few minutes and then drain again and do a proper oil filter change.
As far as the leaking, well you have new injectors, o-rings and the pump is working. I do wonder what the fuel pressure is though. Might be time for a new FPR too.
