Ok 96 ka24de in my 92 hatchback 240sx hasn't been drivable since the swap last year (october). eveything was swaped correctly but I have both electrical and fuel issues im not able to fix now that I need a car to get to work. I have gas in my oil, although I've tested the injectors for leaks, I have two working FPRs , I replaced my old walbro 255 with a new one, I replaced the fuel filter ,and hoses. I dont have a compression gauge or fuel pressure gauge, but my engine only has 98k miles. I dont think my piston rings are bad, but if they are I have another block ready for a build.
As for electrical , my fuel pump will only turn on when I turn the cannon plug for the wires a certain way, and my gauges have never worked ( speedo, rev, gas). code 34 wont go away even though I have already replaced both upper and lower harnesses and the sensor, but I'm pretty sure its because the car is bogging so bad. I hooked up a narrow band AFR gauge which said it was leaning out when I hit the gas and the slowly goes pig rich if I let it idle.
Im thinking about buying ECU talk but im not sure if I should just buy new injectors or a fuel pressure gauge???????????
I've replaced all the sensors and tried my skills with a voltmeter!
Sorry for the novel
[youtube]
http://www.youtube.com/watch?v=yiFS4wKx ... 170ad1a413[/youtube]
Since the video I hooked up the narrow band AFR gauge and FINALY painted the car black. And keep in mind the video was shot on a cell phone thats why it sounds like a mean dirtbike
