Gas in Intake Manifold
jmrussell2003
Car: 1994 J30
I was changing the plugs last night. I removed the EGR tube to get a better angle at plug 6, when I look in the manifold, there was a pool of liquid, turns out to be gas. Sound like a leaking injector?
Also, now the car idles like crap. I replaced the plugs with Bosch Platinum +4, the ones I pulled were Autolite Double Platinums. Only idles rough when it has warmed. It was doing it before, but now it is much worse. Any suggestions?
yodawill2000
Car: 94 Infiniti J30
Best to go with the OEM plugs.NKG Double platinums.Others are known to cause issues.sparkplugs.com has about the best prices.
brandonjustice93J30
Car: 1993 Infiniti J30
I thought OEM's were NGK laser plats?
yodawill2000
per sparkplugs.com
NGK Double Platinum 2647 PFR5G-11 .044" DOHC(Original Equipment Manufacturer, and/or Original Equipment Service Part)
yodawill2000
JM
When you say "Look into the manifold"Do you mean the cylinder ??Like where the sparkplug was ??
gr8scott72
Car: 1994 Infiniti J30t
yodawill2000 wrote:JM
And the egr tube isn't blocking #6 cylinder. Are we talking about the 3.0L V6 in the J30?
brandonjustice93J30
http://www.ngksparkplugs.com/p...24536
I always went by NGK themselves
jmrussell2003
Car: 1994 J30
The tube that bolts to both intakes and runs at the back of the engine. When I removed it, i looked in there on the drivers side of the engine. the gas was in there.
Modified by jmrussell2003 at 4:05 PM 2/22/2008
yodawill2000
Ahh .. Those are the balancer tubes.Thats odd that fuel was in there though. Somebody might have an idea by not I.Thats just the air path before the injector is involved . weird.
yodawill2000
brandonjustice93J30 wrote:http://www.ngksparkplugs.com/p...24536
Ahh same plug .. different name
brandonjustice93J30
ahhh...ok
I'm running the iridiums right now...no noticible issues
misfit6794
Car: 93 J30
You may have knocked lose or torn a vacuum line, or the plug for the maf isn't on tightly. I've got no idea though how you got fuel in there, you may have a leak somewhere, and thats never good.
