onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Mon Apr 04, 2005 6:35 am
Well, I believe when something goes wrong, the ecu switches to a fail-safe mode, which obviously wastes gas.
Um, since you rebuilt the engine, I'm guessing you also did a tune up (i.e. plugs/wires, dist cap, rotors, o2 sensors, checked coolant sensors/switch).
Did you also have your injectors checked, make sure nothing is leaking?
And this is really stupid but: properly inflated tires?
Also there's similar threads about crappy gas mileage, those should give you a pointer.
Lastly, try resetting the ecu (still has saved info from old engine probably) and give it a week to adjust to the new engine (they remember last 50 start ups & driving patterns or somewhere around there)
