to slightly expound on that, the fuel pump is inside the tank as im sure you knew, and the gasoline in the tank is what keeps the pump cool. Running it that low makes it so gas isnt surrounding it as it should.stock1992q45 wrote:I know because the gauge returns to the previous level.
That's interesting about the 1/4 rule.
Thanks for the tip.
