killbillet wrote:turn your acc on first and test all of your fuel pump wires with a volt meter, if its all good, there is a float that is a part of the fuel pump assembly, The fuel pump and the float is sold separate. When you take out your fuel pump you will see what im talking about..but if i can find a picture of the whole assembly ill post it so you know what to look for hope this helps
so the float might be bad??? or sticking?
also could there be maybe a wire grounding out on the gauge itself? idk farfetched but possible?
