Gas Gauge went crazy...help please?
HailtotheSilvia
Car: 93 S13 coupe
just to mention first, i did use the search button but i couldn't find any write up on this....
I just fill up my tank to day...full and drove around a bit then park my car. About an hour ago, i got bored so i decided to go for a drive around town. Then half and hour later i noticed my gas gauge dropped to E....on its own.. I parked my car immediately and check for leaks..nothing. I decided to take it easy and drove it home slowly and check for leaks again...nothing. here whats the car does- when i accelerate the needle slowly moved back up- when i come to t a complete stop..the gauge dropped back down to E.
Sound like an electrical issue right? at least i hope it is. Tommorrow i'm gonna pull the fuel pump and check the sender unit, hopefully it's not mess up. If you guys have any input on this please let me know...
Thanks
Tao
GEO
Car: 95 240sx KA-T
My car reads high.. Liek ti says its empty but there is like 6 gallons left.
HailtotheSilvia
Car: 93 S13 coupe
anyone else?
Ramius83
Car: 1995 240sx SE
It is your fuel level sending unit located inside the fuel tank.
Usually runs about $20 to $60 depending on the junkyard. Not too hard to replace, take a look at the FSM for details....
gogg
Car: 89 240sx silver hatch (burrito)
Probably my crappy wiring at the ECU/dash harness, check that.
