Gas Gauge stuck at 3/4 or empty after fill up!
rvof91773
Car: 2003 G35
New to this site! hello fellow G35'rs, been having this issue for a while, where after i fill up the gauge will NEVER go higher then 3/4 even though its completly full or some times after a fill up gause stays on empty position. Any help would be greatly appreciated!
zozoka1212
Car: 08 Infiniti G35x
Are you sure it is full? Some people having issues with the valve shutting off the pump early. I'm sure you can find something if you search on the side. Not hard to get to the tank. You have to remove the rear seat.
RobTurbo
Sticky float? Like said above easy to access and check it out
bina12834
Car: 06 G35 coupe
take it to the dealership, if youre still under warranty it will be a free fix
biggie
Bringing this back up.
I've having a similar issue. Gauge is basically reading a 1/4 lower than it should, but then sometimes is normal. Wonder if that will be covered under any normal warranty or if its going to be past warranty on the ''03?
bina12834
Car: 06 G35 coupe
ive had mine "fixed" by the dealership twice so far and its still not right. thankfully im still under warranty.
