Gas Gauge Question
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
lazeballz
Car: 03 Civic, 89 integra, 92 integra, 08 Versa, 85 Datsun 720
I tried searching but it seems as if the search isnt working proper?
My gas gauge is stuck/isnt accurate. Anyone know of the first things I should check?
Also, are there any stickies/FAQs for the most common of problems for our truck?
lazeballz
bump"?
PEZi
what exactly is it doing? just staying in one spot or moving around slighly?
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Hope this will help. Incorrect reading - check the tank to see if the bottom is dented. This prevents the float from showing below 1/4 tank, or check the float to see if there is a bridge in the winding. Not reading - clean where the tank is mounted to the truck, this ensures the grounding for the float. Or check the wiring between the float and fuse box by using a multimeter, setting the meter on ohms. Any reading above 0.0 indicates a cut or disconnected wire. If it is sticking well change the instrument panel.
lazeballz
thanks for the advice. I never understood how the gauge on the gas works. Ill be sure to check those over the weekend.
Return to “Datsun 720”
