Gas Gauge Problem...
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
alientravler
Car: 1982 Datsun 720 4x4
Anyone know if there is a fuse for the fuel gauge??
PEZi
i don't believe there is one specifically for the fuel gauge... i think its one fuse for all dash gauges
i'll double check my manual later if no one else figures it out for sure before then... my guess is there's something else besides a fuse bad however
alientravler
PEZi720 wrote:i don't believe there is one specifically for the fuel gauge... i think its one fuse for all dash gauges
I think you be right! I just got back in from testing all the fuses (Rain let up) and all are good. Looks like the wires are connected on top of the tank as well. Guess the sender is shot!!
Aven
Car: 84 720 Kingcab
Alientravler, were you able to check the ground connection? That's on the list of things that need to be dealt with on mine as well. I've been reading everything I can find on it and the ground seems to be a very common cause. I'm hoping its the ground on mine because I really don't want to drop the tank. If it comes to it I'll probably take the bed off instead.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Aven wrote: I really don't want to drop the tank.
The tank is a real pain in the a** to reinstall. A lot of issues are corrected just by ensuring the ground system is good on these trucks as so many systems are tied into each other.
alientravler
Thanks Guys!! I'll re-check the grounding again. Maybe try a add-on ground wire to the tank??
flinterman2000
Grounding the tank might help, but you should check the grounds along the harness as the gauge's ground is through the harness. Whats the actual problem with the gauge. When I bought mine the wire to the tank was severed at the entry point to the tank. Not an easy repair as insulation is necessary.
alientravler
Seta below "E" all the time.
flinterman2000
Should have replied earlier. There are two wires on the float, the sending wire and the ground. Try grounding the sending wire with the ignition switch on. If the gauge reads then its the entry to the tank where the problem is. I used a screw and nut + a plastic wall plug to secure the wire for the sending unit, once thats secured, cover the screw with epoxy steel to seal the tank. Remember its not as easy as it sounds. Good luck.
PS you will have to remove the tank or tray for this fix.
alientravler
Thanks Man! Thats the info I needed!! I'll check it out tomorrow. Fingers crossed!!
flinterman2000
Any luck so far?
alientravler
flinterman2000 wrote:Any luck so far?
Looks like its in the tank as far as I can tell...guess that end is not working right!
flinterman2000
I'm lost. Did the gauge read when you grounded the sending wire?
alientravler
Yep!! Crap!!
Return to “Datsun 720”
