Pescakl1 wrote:Probably because you don't fill it up. You may stop about between the two and since the gas is colder, when you driving, the gas expands and fill the last square. It may be also due to the imprecision of the gauge.
It happens some time to time when I drive. I am, let's say, half full (or half empty, depending of the price of the gas this day ), and after my commute to work I have one more square where I should have the same quantity or one less (my commute is about one square). Unfortunately, it won't stay in the car . It happens also the other way around when the car stayed under the sun, I have more gas but I lose it faster when I drive home.
All that sounds normal to me, fuel gauges were and are still never precise, that is the a fact to deal with.
That simply cannot be the case because I tested that as well; a lot of the time I'd fill up after I got into town at the end of my commute from work, as soon as I turn the car on after filling it up, it shows one block short of full. The next morning when I first turn the car on in the morning, it shows full, all blocks, and generally speaking I need to drive easily more than 55 miles before it finally drops one block, as I'll drive to work and home (50 mile round trip commute) and I still have full, every block. It'll usually drop one block about halfway to work the next day after that for me.
-Ed
