Gas Gauge moves
Sdavne
Car: Nissan 300zx n/a 2+0 5 speed sliver
Any one have a problem with their gas gauge, it bobbles and when braking it moves up and when accelerating it goes down and after driven and stopped it moves up and down, i am thinking it is the float but i am not sure also if this has happened to anyone and they know how to fix please let me know thanks.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
That's what I'm thinking as well. Is it a significant amount? Is it still reading accurately?
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Could be the float, but also check the sender connections on the top of the fuel pump.
Sdavne
Yeah it moves alotand not really its off by a couple gallons
Ace2cool
According to your post in the other thread, it's right on the money.
Sdavne
thats what i was thinking, do you know how to fix it?
aroche25
Car: 2007 Mazdaspeed 3 GT
Looking for a Z32 Slicktop
You might want to try some fuel system cleaner, it worked for me when my gauge was doing that. Now it still does it but you have to really watch to notice anything at all.
Ace2cool
I'd stay away from fuel system cleaner. It's designed for cars without pintle-less injectors like ours. Injector cleaner/fuel system cleaner is known to eat away at the discs that make our injectors work. Seafoam is a safer alternative, but you'll want to change your fuel filter afterwards.
aroche25
Ace2cool wrote:I'd stay away from fuel system cleaner. It's designed for cars without pintle-less injectors like ours. Injector cleaner/fuel system cleaner is known to eat away at the discs that make our injectors work. Seafoam is a safer alternative, but you'll want to change your fuel filter afterwards.
Seafoam is exactly what used, also besides the filter if you use it in the intake or oil you need to do a oil change shortly after.
Sdavne
What about if you do it from the booster line?is that good or not?
Ace2cool
It's great for use in the brake booster line, but a lot of people have been doing it to the small vacuum lines on the throttle bodies, since it will go to the cylinders more evenly. I think Tony knows a lot more about this method than I do. I always used the brake booster line, but that method doesn't evenly spread to all the cylinders. The front two are going to have minimal seafoam effect.
