Gas gauge LIES!! Said 1/2 tank but went empty on hwy How to fix
Arlo
Car: 2006 M35x
My gas needle is a lying whore and it's driving me crazy. :mad: I did some googling first to find and fix and came across this guy named Vlad with a G35.
Passenger side
Drivers side
I know our cars are very similar. Curious to see if any of you have experienced this issue and if you think this fix will work for us as well.
Thanks
Reason: FIX IMAGE LINKS
Larz
Car: 2019 Q70-L RWD
You're right. Our cars are very similar. I remember a post about this maybe 2-3 years ago. The search engine could not find it. However, if I remember correctly the side that reads the fuel level is opposite the side that contains the actual fuel pump so you may not need to mess with the side that has the pressurized fuel line. I recommend cleaning the side that has ONLY the connector to unplug first. I also would remove the battery terminal before I did anything like this to remove the possibility of any sparks or arching near fuel vapors. That's probably completely unnecessary, but I'd do it anyway.
Hopefully Ed will see this post and correct us both if we are wrong. Ed is our resident guru for anything M-related. I believe his member name is EdBwoy if you want to message him.
Arlo
Car: 2006 M35x
I will ping him and thank you very much for your input.
Turnert
Car: 2003 infinity m45
My 2003 m45 had the same problem. I looked it up and it had a recall for the fuel gauge so I just took it to the dealer and they fixed it for free. Maybe see if yours has a recall for the fuel gauge as well.
kmiles
Car: 2015 Q70 3.7 AWD - Hermosa Blue
Sold - 2007 M35x
I'm a believer in doing the least invasive thing possible when it comes to the gas tank. I would start off with adding a can of SeaFoam Motor Treatment to the gas tank just before filling up. I've been amazed how it had fixed various issues on my M35x such as when I couldn't fully fill the tank or the idle was starting to run rough.
EdBwoy
OP, do you typically fill the tank?
I wonder if you're having some "sticking" issues. I haven't watched the videos, but from the thumbnail I reckon some electrical contacts get cleaned.
You actually have fuel level units on both sides of the tank, so unless you actually have a code (pending or CEL) pointing at a particular issue, I'd check them both.
I'd start with the left one, it's less complicated.
