compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Fri Mar 02, 2012 12:09 pm
You can bend the needle so it makes contact again. The sending unit is in the gas tank. To fix this and confirm its fixed, pull the fuel pump fuse, pull the sending unit turn the key on and move the float up and, down and if the needle makes contact through the entire range it should make you're gas gauge should move accordingly. Google ”how to fix fuel sending unit” and there are some how to videos that should be helpful.
