CDE »
https://forums.nicoclub.com/cde-u24869.html
Mon Feb 21, 2005 7:38 pm
definately injectors.
does it idle a bit rough too?
I had that prob and replaced injectors 2 and 3 and viola, all better. Although, I would make sure it is indeed the injector, and not just the seal. If it's just a seal, that saves you a few hundred...if you do your own work.
SxMachine, here's a test to see what injector it is - start it up, open hood, and wiggle each injector. When the engine sputters or does anything different, then it's that injector. And like I said, just check the seal first before you go and buy all new injectors...at least where I live I couldn't find injectors for under 100 bux ea.
