Gas coming out of my exhaust
jfklogistics
Car: 1990 Nissan 300 ZX
Help.I have a 1990 300 ZX non turbo. I just purchased the car knowing it had a problem with fuel "running " out of the exhaust pipe. The guy I purchased from had a " Mechanic" install all new injectors and he replaced intake manifold gasket. Car starts but fuel runs from the exhaust..........Plz some advice :confused:
GerryO
Car: 1993 J30t
Pearl White
Black Interior
1) don't start the engine again
2) don't crank the engine, except maybe with all of the spark plugs removed and the fuel pump fuse pulled, and in order to perform a compression test
3) park the car in a cool shady place, remove the fuel pump fuse, take and leave OFF the gas cap, relieve pressure on the fuel system, keeping things away from any open flames
4) order six new pairs of upper and lower fuel injector o-rings, a new plenum gasket, two new PCV valves and a few other plenum related gaskets, o-rings and hoses
5) remove the plenum and the fuel rails, and carefully install new injector o-rings
6) unclog/clean your EGR tubes
7) you may also want to replace all six injectors with new OEM injectors (not reconditioned) and check/clean/do any number of other good things while you are at it.
8) change your oil and filter, as fuel has probably gotten into the oil pan
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
$20 says they pinched and tore an o-ring or lower plenum seal and the injector is dumping fuel into the cylinders now.
inlowm523_90tt
Car: 1990 Z32
lol i will bet 20 bucks with BIGTDOgg.....i pinched multiple times....he is correct.
