gas and boggles. intake back fire?
AsanBBoy
So it idles fine, but give it some gas it boggles like hell and could die. I guess it seems to have a intake back fire form the sounds of it. There is a lag between throttle and sucking inn air. Reving it any higher than 3 is not possible most of the time. It is throwing no codes and i do not know what to do next. Any help? I have a video don't know if it will help much (I took it side ways...).
http://videos.streetfire.net/v...c.htm
edit, perhaps the timing chain is off? I dunno how though. When I was running the car with a turbo set up, it was idling fine and reving fine. Now this?
Modified by AsanBBoy at 11:14 PM 3/22/2007
Modified by AsanBBoy at 12:50 PM 3/23/2007
VeloceDrift
Car: 1993 Nissan 240SX S13 coupe
1995 Nissan KA24DET
so you have your MAF on? same **** happend and my MAF was unplugged
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
- check the MAF- possible major vacuum leak
AsanBBoy
Yes I have my mafs on. When i start it without it, idle is bad it jumps up and down to about 1000rpms and dips to about it dies but it doesn't. Bad mafs? I do have another one but i think i tried swaping it out already.
jspecg35
Car: 2004 Infinity G35
Check your vacuum lines, sounds like you might have a leak
dkdeleon68
Car: 1991 240
sounds like one of the injectors is not pulsing, check your oil to see if it smells like gas.
