02_silver_wagon wrote:I think the upgrade he spoke of would be engine internals.
Go to the Precision Turbo website and look at the max hp for the sc50 which is a 50 trim t3/t04e, it is 450hp. So I would say the max whp on a 50 trim would be 400whp. Looking at the compressor maps it looks like the 50 trim would still be fairly efficent at 30psi. Hope this helps.
The max HP is debatable. While 450 HP is not a bad estimate, another rule of thumb is to multiply the airflow in lbs/minute by 10. A T04E-50 is rated at 47 lbs per minute. Also keep in mind that the peak flow rate usually does not occur at peak boost. The T04E-50's peak flow occurs at a pressure ratio of about 2.6, or 1.6 BAR. This of course doesn't tell the whole story either. The turbine flow, presence of, efficiency and pressure drop of an intercooler can affect this as can maniold design, compression, etc, etc, etc. Also considering that we do know of at least 1 15 psi KA putting out 350 at the wheels, at 15 psi, the KA will probably be pumping in about 32 lbs/min of air. By my rule of thumb, that's only 320 at the crank. There is no easy science to this. And it's good to think about this. But my point is that results vary based on conditions.
