Ya i was just double checking i also have some questions what parts do i need besides a mani to go top mound and what psi can it do?AZ89two4Tsx wrote:Well, obviously you thought so since you bought it.
Thanks man im looking trew there right now.1SickSilvia wrote:Also there is alot of help in the KA-T section on the forum regarding your questions.zeroforum?id=170
300whp isn't going to happen with any T3 compressor, at least not without pushing it beyond its limits with a really agressive tune (race gas).S13-Chuki wrote:damn i thought it could do atleast 300 its going on a s13 sr20.im thinking of selling it to a buddy.
I've seen T3 "Super 60's" with a .82 turbine housing pump out around 270whp but thats pushing it. Its hard to know exactly which compressor wheel you have without measuring the inducer and exducer but it looks like a 50 trim. A 50 trim T3 with a .48 a/r turbine housing is good for about 200whp but thats it. It could build lots of low end power but it will run out of breath long before redline.
Are you serious?!?! Quit spamming this thread with garbage. Here is a dude that hit 284WHP (mustang dyno) at 11PSI. Did I mention it was a T2 flange?!?Skilz10179 wrote:
ashibah83 wrote:
are you on crack???
i know of WAY too many people pushing good numbers with t3 frames, a good friend of mine ran a T3T04E to 430whp on his integra, that t3 would be an upgrade from a t25 and they can push near 250
romerider153 wrote:i made 377whp 356torque on a sr with a gt30 which surprise surprise is a t3 frame so yea your stupid
I am sorry but you guys don't know what you are talking about.AZ89two4Tsx wrote:
Get out if you're gonna post stuff like that.
Thats what my friend was telling me to do my power goal is about 350 hp.Kalypso123 wrote:If you become an expert and do some real research... you mind find a compressor housing and wheel from a t4 or other turbo that you can swap unto yours
keep in mind that turbo can be rebuilt and modified if you have the right parts and get it balanced when your done...
take it to a local shop... if they can swap the cold side for something bigger... and do it for under 200 bucks you have a mean 400+ hp turbo... for 450$
with a little lag of course... but your turbine side is petite anyway so it should spool quickly
