This is my first post--quick intro: My name is Adam, I have a SOHC 90 240 coupe. Planning on doing an SR swap in the coming months after refreshing the motor and such. This is my second 240. I also have a 99 Z28 that has an LS1 with tons of goodies. I've had several sports cars, but mainly muscle cars. I'm on several other forums, same name-although this is my first Nissan related forum.
I just got a redtop from a local shop and am breaking down everything replacing gaskets and seals, etc.
Took off the turbo and noticed that there is a ton of oil and oil/water mixture coming out of every orifice. When everything was on the motor, there was a small pool of oil in the inlet...didn't think too much of it...pulled everthing off (lines, manifold, etc.) and I noticed that a nut was missing in the mani-turbo flange-and it was loose as hell..weird. I've turned the turbo ever way (upside down, around, up, down, blah) and I just poured an oil/water mix out of the outlet. I also noticed there was oil coming from behind the inlet wheel and a little in the hole where it bolts to the manifold. Looks good on the exhaust side, no oil leaking there. The fins look good, and the shaft seems to be fine (has a small amount of play).
My question is this:
Is this normal for a used turbo that's been disconnected and moved around a lot? Or, are the seals inside the turbo bad/ does it need to be rebuilt? I've searched around and found nothing. Someone who knows more about turbos may be able to enlighten me..where does the oil and water reside? Will it come out of these places if jostled? Any help is much appreciated!
PICS:
If it takes too long to load, go here: http://s1270.photobucket.com/albums/jj611/BlackZ28629/
