Darius »
https://forums.nicoclub.com/darius-u5470.html
Tue Apr 13, 2010 10:47 am
"I bought a T04Z from ATP a couple months ago and was curious to know if you recommend running the .035" restrictor on the oil feed line to the turbo?
Thanks,Matt"
Their response:
"Matt,
Never ever use a restrictor unless you have determine that the engine will put out too much oil for the turbo to take. Worse case if it leaks, you can always add a restrictor and problem goes away."
I think I'm going to throw the restrictor fitting on there to be safe. Thanks guys!
