Daidae wrote:I'm not knocking the GT2871R, but it looks like it best for straight runs. If you look like at the dynocharts from ATP, the GT28RS with give the GT2871R a good run for it's money on a twisty race track.
ATP Dyno Chart:
But that dyno was done with a pretty small engine that probably has a corked off exhaust tract. A GT28RS isn't that big of a turbo, so it hitting full boost in the 4.5k RPM range points to a mighty small engine.
Taking into account that a 2.0L engine will spool up a GT2871R just slightly after a GT28RS(200-300RPM or so?), but make a good deal more torque all the way to redline, I think it looks like a better solution for someone wanting 320-350rwhp. Plus I'm not sure of the turbine A/R on that dyno.
I'd think a 0.64 A/R turbine GT2871R would tend to spool pretty close with a 0.86 A/R GT28RS, but make more power due to more compressor headroom. Power might drop off above 6.5k RPM due to increasing exhaust pressure in the exh manifold, but I'd be shocked if you didn't make more power than the DP all the way to redline with the 0.64 A/R GT2871R.
To me it kinda seems like a 0.86 A/R turbine is a bit large for the compressor on the GT28RS. 300-310rwhp seems well within the ability of a 0.64 A/R housing's flow capacity without killing power.
