garret gt2871 on a ka24de
jongonzoS13az
Car: 90 240sx
are there any kits or anything that would allow you to use this setup or is it a custom job?
boznuttz
Car: MS13
I'm sure you could find someone selling their old T2 setup...but in my opinion, they are pretty expensive.
What power goals and usage would you be looking to achieve?
jongonzoS13az
Car: 90 240sx
i actually found a kit. um 400 hp region i just like the bb action quick spool great boost
boznuttz
Car: MS13
If you found a setup within your price range, then go for it!
I've seen GT2871r's going for around 1,000 bucks, and T3/T4oe 50 trims with exhaust a/r's of .48 to .63 for around 200 to 300 bucks. They can both get you into the 300 to 400 hp range, but one is easier on the wallet. The previous owner of my T3/T4oe 50 trim .48 compressor/ .63 exhaust saw over 350 at 15psi, and claimed to get full boost around 3,700 rpms.....not bad at all really.
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
boznuttz wrote:If you found a setup within your price range, then go for it!
T3/T4 is the better route, for uprgrading purposes, but when you look at getting a manifold and downpipe and an external wg, it comes out to the same price as getting a cheap bottom mount mani and gt2871. just some perspective.
jongonzoS13az
Car: 90 240sx
i was reading that the t25 topmount kinda sucks cause of its location its close to the master cylyder which ill prob chang for a 300zx master which is bigger and they said no ac either is the t3 forward mount better?
jongonzoS13az
Car: 90 240sx
how do you run a bottom mount on a ka?
ghx407
Car: 1993 240SX KA-T
You can get one of those inexpensive ebay T2 tubular turbo manifolds for the KA, reinforce the welds, and use an aftermarket SR dump and downpipe. Everything should bolt up pretty easily.
boznuttz
Car: MS13
jongonzoS13az wrote:how do you run a bottom mount on a ka?
Just take a peek at my sig!
It's a T3/T4 that is actually larger than a gt2871r turbo on the bottom of a bottom mount t2 Ebay manifold. The only modifications: tig welded a t3 flange right on top of the t2, lol.
GTR PrYdE
The wg dump off the manifold goes up though right? No creep?
boznuttz
Car: MS13
No creep at all, tested at 15 psi too on a previous setup.
GTR PrYdE
Pretty sweet. Pics of the o2 housing? And...
Yall should make these and sell them
ghx407
I got pretty much the same thing as boznuttz, only upside down. It works good.
sunnys14
Car: S14
cost of a gt2871r .86AR turbo setup:
turbo - $1000SSA manifold - $150SSA turbo elbow - $100
cost of a t3/t4 turbo setup:
turbo $400manifold (JGS) - $380downpipe (JGS) - $225external wastegate - $200
For 370whp setups, they're comparable in price. Anything more than 370whp then the t3/t4 is a better choice.
boznuttz
Car: MS13
Plenty of room around the downpipe. It aint pretty, but it works!
boznuttz
Car: MS13
I originally was thinking about doing a similar setup with flipping the bottom mount T2 Ebay manifold upside down, but I had worries about the downpipe being too close to the BMC. Of course I could have probably welded a T3 flange at an angle to avoid that issue, lol. Oh well, it's more stealth the way it is.
