Good Buy!
We have been using a Garman C330 for the past 3 years and if you travel to 'never been there before' places like we do it will get you there and get you home. Your unit should have the latest maps...our maps are getting dated in the newer subdivisons around Dallas. Damn progress!
I use it in our Honda Odyssey mounted on a plate that I built that fits in the pull out ashtray.
However when we tried to locate a good spot in the Versa, it was tough to find a place that kept it out of sight, but still visible to use. I found that the big round suction cup on the mounting arm fit perfectly in one of the cup holders in front of the shift lever.
Trouble with that location is it can't acquire the satelight signals down there under the dash. The solution was to mount an auxiliary antenna up on the dashboard and run the wire down to the unit. That works fine and the installation looks, factory.
There is a small removable plastic cover up near the windshield on the passenger side I popped it out, cut out a hole that perfectly matched the antenna body glued it in and then ran the wire down behind the glove box to the unit.You can check it out here...........................................................................,
http://picasaweb.google.com/longo3002/VersaPics#
Use the "Slideshow" feature to enlarge and auto scroll the photos on the albums.
And here...........
http://picasaweb.google.com/longo3002/VersaPics02#
