This would be my place to check... Open the filler neck after the car is completely cool and make sure the coolant is to the top. I've had this before and it's always a low coolant situation.maxnix wrote:Have you changed your coolant lately or broken into the system?
Purge the air in it.bigdog76 wrote:Filled up the coolant and it is still doing it any other suggestions??
You still have air. Use distilled water and follow Jesda's advice. Don't use taqp water under any circumstance.bigdog76 wrote:Filled up the radator fluid and the noise is still strong.
What else could it be??
Why we keep saying to purge the system.bigdog76 wrote:He says there is air in there.
Dealer tells ya that, eh? Does the dealer realize Datsu..... er, Nissan stopped using water valves on the heater in the late eighties, and temperature is adjusted by an air-routing door? The core's full-time, full-flow. And your dealer's fully-full, too. We won't say what of on this forum.bigdog76 wrote:Dealer told me to run the heater for a while and that should clear it up.He says there is air in there.
Apparently, the guys who wrote the FSMs didn't get the memo either...Defiant wrote:Dealer tells ya that, eh? Does the dealer realize Datsu..... er, Nissan stopped using water valves on the heater in the late eighties, and temperature is adjusted by an air-routing door? The core's full-time, full-flow.
KEY words you said"cap stopped leaking" if cap leaked,it also was not air-tight,allowing it to suck in air on cooldown.... why problem didnt go away before---Replace that cap if it was/is leaking,obviously has a bad seal...bigdog76 wrote:Fix was I opened the cap ran the car till some cooliant came out (of course while the car was initially cold and then I capped it.
Few days later the sound stopped and the cap stopped leaking after that.
1.) Repeat your mantra, OEM OEM OEM OEM......bigdog76 wrote:1.) Thats exactly what I though before when I replace the cap before with a cheapo from autozone.
2.) The radiator is not stock oem it has been replaced which should constitute me not having to have a oem cap.
