FrEaK »
https://forums.nicoclub.com/freak-u375.html
Fri Apr 04, 2003 10:37 am
1)Do a leakdown test or a compression test, record the values.
2) Drip a small amount of oil into the cylinder (nomally in through the spark pul hole), turn it over a few times.
3) Redo compression test, if the numbers are closer to spec you have worn rings chances are.
4) Depending on the future of your engine, will decide what you do after this point.
