I have mine in the same place because my sunglasses don't fit there. I just hate how it rattles when I'm listening to the stereo, but it kept popping off of the visor so this is the easiest place to access it.bulld0g wrote:I have mine in the sun glass holder on the roof....just took the clip off the back
My 2007 SL came factory-equipped with a color-matching elastic sock around the visor that holds my (small) opener completely out of sight. Check to see if you have one, if so, see if the metal clip on your opener is removable.RustyC wrote:I have a new 2008 Versa Sedan. Does anyone have any ideas on where to put the garage door opener? The drivers visor is way to thick for the metal mounting clip on the opener....
Thats the same place I keep mine. Out of sight and easily reachable. And as for the size of the visor....I commented on that some time ago. These things are freakishly huge.rwanttaja wrote:My 2007 SL came factory-equipped with a color-matching elastic sock around the visor that holds my (small) opener completely out of sight. Check to see if you have one, if so, see if the metal clip on your opener is removable.
Ron
