Gains of an adjustable fuel pressure regualtor?
Spidey
Car: my car
I'm thinking about putting a fuel pressure regulator on my car a shop told me it was good invetment to keep me from running to lean on my Sr20.
I want to know the advantages of getting one on besides the one previously stated.
Are there any other gains from it?? How would I know if it made a difference, with out a dyno????
any input will be greatly appreciated thanks.
PabloHoney
the only way you are gonna know is if you run it on a dyno and use a wideband O2 to tune it. I recommend getting a rising rate fuel pressure regulator if you are gonna go that route.
Spidey
Car: my car
what is a wideband O2??
PabloHoney
it's basically like your regular O2 sensor that's in your exhaust now, but widebands are 5-wire and much much more sensitive than regular O2 sensors. Dynos use them for tuning, er SHOULD use them.
Spidey
Car: my car
the regulator I will be getting is a Tomei it has a bolt and a locking nut.
If I twist the bolt downward will that give more or less fuel pressure?
How do I know if it has made a difference??
Is there any disadvantages???
Thanks for your help
Spidey
Car: my car
wanted to add:
would an adjustment on the regulaor change the readigs of an stoich gauge??????
mattback
Car: being a big f'ng ricer
screwing it down would tighten the screwmaking it stiffer
raising base pressure
Spidey
Car: my car
but will adjusting it show up on a Air/Fuel ratio Gauge???
PabloHoney
A/F gauges are worthless for tuning purposes. You need to get it on a dyno to tune it, period.
Spidey
Car: my car
Thanks thats all I needed to know.
One more question where can I find a wideband O2 dont meen to sound ignorant but how much do they usually sell for?
PabloHoney
you don't have to buy one, the dyno shop should have one hooked to their machine. Funny thing also, a lot of the replacements for those sensors, can be bought at Honda. The O2 sensors used in a lot of their newer cars are wideband =)
