Cjmartz2k »
https://forums.nicoclub.com/cjmartz2k-u65761.html
Wed Nov 04, 2009 1:20 pm
I don't think that part of the headgasket is going to see a lot of cylinder pressure, you'll be fine. What Darius meant was ignore what the internet says. Stock HG's are the best sealing, best performing gaskets out there. They aren't going to blow out because you X amount of boost. It's all about cylinder pressure anyways. What do you think 30psi of boost is compared to the 100's if not 1000's of psi of pressure the cylinder sees when the air/fuel goes bang? That's beside the point. Only reason for an aftermarket gasket is for a different size.
