rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Wed Oct 12, 2005 10:04 am
Ok, so I replaced the calipers. BUT, I still have crappy pedal feel...as in none. Once again, when the car is off, and I pump the brakes, I get full feel (aka rock hard LOL), but with the car running, there is little pressure (it has returned a bit since the new calipers/bleeding the brakes, but not like it was) I pulled the vac line off of the booster, with the car off, and there is a WOOSH of escaping pressurized air, so it is holding pressure. Any more ideas?
EDIT: I did some more NICO archive searching, and I checked for booster leak by listening (with the car on) around the brake pedal under the car. Also, the brakes DO in fact work...well. I just have to push the pedal much further to get any results. Also, my ebrake needed to be pulled much more to get it to work (previoulsy, I had it adjusted VERY tight, and I had to retighten it again....I assume this is unrealated and has to do with the fact that the ebrake cable was removed and replaced on the caliper) This really sucks, until 2 days ago, my brakes were bad a$$. Now they remind me of my gf's Cavalier
Further EDIT: I checked the FSM on booster inspection, and it is fine. I am going to try another bleed session, and see if that gets me anywhere.
Modified by rico05 at 4:54 PM 10/12/2005
