shanomak »
https://forums.nicoclub.com/shanomak-u191849.html
Sat Oct 08, 2011 9:37 pm
a quick continuity test with a meter should be able to pin point the brake in the circuit board behind the cluster. once you find it just scrape off the epoxy in the are and drop you some solder on top of it and then melt it to the trace, but be VERY careful you can make the problem worse if you get too much heat on the board.
