BeyondBiscuits2 »
https://forums.nicoclub.com/beyondbiscuits2-u45101.html
Thu Feb 21, 2008 6:09 pm
The last manual is the exact one I needed! Thank you so much!
I just solved both major questions I had: 1. do all Nissans have the same "type selector", 2. which Nissan engines use what "car selector". To answer no. 1, it is yes, except for the Nissan Terrano (no matter to me). No matter what type or size of engine, it is all the same: up, up, down, down, down, up, down, up. For no. 2, all of the SR-series use setting "6", and since both the SR20DE and KA24DE both run the 259cc injectors, I think that is the safest bet for me to try and use. If the "6" setting doesn't seem to be working well, I might even try the "9" setting for the CG10 and CG13, which are basically tiny GA-series engines.
As for the same injectors as the GA16DE, I think the VG30E (with side-feed) use the same injector, but just six instead of four? They are both pink in colour, and the only "pink" Nissan injectors I can find listed on that nice Nissan injector list floating around are for the GA16DE?
