Postby
thatirishkid2010 »
https://forums.nicoclub.com/thatirishkid2010-u50411.htmlFri Nov 10, 2006 12:52 pm
I have a 1994 nissan sentra se with an GA16DE engine and i am planning on putting in a SR20DET GTIR engine. the GTIR comes with the engine ECU and wiring harness is that all I need for the swap to work? or do I need any extra parts?
Postby
Logan76 »
https://forums.nicoclub.com/logan76-u38992.htmlFri Nov 10, 2006 12:55 pm
you may need a transmission your gunna wanna replace your water pump, and your clutch, those are just 2 of things I reccomend to replace when you do a swap.
Postby
Chris859 »
https://forums.nicoclub.com/chris859-u44940.htmlMon May 07, 2007 7:38 pm
Dont forget - you will also need an SE-R clutch, and flywheel! The gtir flywheel is larger than the fwd sr20 flywheels, and won't work with the fwd transmission.
