I'm not 100% familiar with NVCS. It sounds like a precursor to Nissan's current valve control systems. The question is what exactly does it control - lift or duration or both or what?
From there I can probably make more sense of how it works. My guess is that it controls duration via oil pressure, as lift would require a separate or variable cam assembly itself. Assuming my guess is correct, angle stays constant while timing changes.
If you want, I can put this in our engineering forum. Someone in there is more likely to have a true understanding of how this all works.
Here's a link to that forum for if/when you want me to put it this thread in there -
zeroforum?id=88
